Issues with MIDI on Multiple Wire Clips
moldybeats
Post by moldybeats »
I recently noticed that if I have multiple clips using sources from Wire (different Wire patches, on different layers), and I assign MIDI controls to parameters on both clips, the clip will only respond to MIDI control if it is selected. Meaning: I can't control clip parameters on both clips at the same time. I have to select the clip before it will respond to MIDI.
Seems like things work fine when the clips are not using Wire sources, or when I'm assigning MIDI controls to layer parameters.
Anyone else run into this?
Re: Issues with MIDI on Multiple Wire Clips
Check the shortcut target in the midi mapping:
https://resolume.com/support/en/midi-sh ... cut-target
You might need to use "This ..." instead of "Selected ..."
moldybeats
Perfect, thanks! That got it working for me.
