iPhone as camera input
ssissjo
Post by ssissjo »
We have been using the Iriun app on the iPhone as an onstage live camera for Avenue, but it has been a bit unstable, sometimes showing a sleeping cat instead. And after the last update to Sonoma and Avenue 7.18 it doesn't work at all. Any other iPhone app to use? I have seen NDI mentioned on the Forum, but a search for "NDI" on the App Store gives many results. Exactly what apps do I need to have on the iPhone and MacBook?
Alternatively, what not-too-expensive wireless cameras could we use? Stability and low latency is more important than resolution and picture quality.
We play mostly small venues, distance between laptop and camera typically within 15 meters.
Re: iPhone as camera input
ssissjo
Post by ssissjo »
Continuity Camera also works to get your iphone camera into Resolume since Ventura https://support.apple.com/en-gb/guide/m ... 0/mac/15.0
