Slice Transform Render
Jethorse
Post by Jethorse »
Hey,
Just curious, will you ever implement a feature where I can add the slice transform effect on to a clip and add it to the render que to have it rendered in the new shapes built in advanced output?
Re: Slice Transform Render
You can record the output screens now with all the transformations.
Clip rendering should be able to use the input slices via slice transform, this has a bug which will be fixed in an upcoming release.
Jethorse
Post by Jethorse »
Thanks for the reply. I guess this was added after version 7.13.2? must be time to update my license then
7.17 I believe, yes
