Creating and Swapping Collections
fresnobob71
Post by fresnobob71 »
I have a simple grid collection in which I write the colors as a collection of 25 float4 values.
I can do things like use write to write single color changes to the index as an integer. And I can do more complicated collections with span and sequence.
What I can't figure out is how to change the different collections via user input.
How do I toggle the input to the index of write?
https://ibb.co/b39XCkV
tijnisfijn
Re: Creating and Swapping Collections
Post by tijnisfijn »
just use a gate node make sure its set to signal. a gate can have many inputs that you can switch between....
fresnobob71
Perfect, thanks!
