Using Flash Text Option in SWFs
foceye
Post by foceye »
hi... can ANYONE give me a step by step instructions in how i can use the dynamic text option in resolume for SWF files? every swf has a text tab where one can type stuff... What do i have to do in the FLA to use this function in Resolume?? thank you!! step by step as in
1)
2)
3)
would be most appreciated!!! you guys rock!!
> R
normal
Post by normal »
1 right click on loaded clip in deck
2 select text tab
3 type your text!!
We have extensively documented this in our manual:
http://www.resolume.com/support/manual- ... oc78124843
