Some basic questions
JoeyVisuals
Post by JoeyVisuals »
Hi everyone,
I just started messing around with Resolume and followed the Basics course. After having done this I have some questions.
- How do you delete a slide in your composition panel if you don't want it there anymore?
- How do you get visual effects in the Resolume Software and how have the visuals which were already in Resolume Arena been made?
- Can you create your own visuals by lets say taking pictures of nature outside and put them in Resolume to modify them?
Online
Re: Some basic questions
Right click menus usually have a delete or remove option.
There is an Effects panel holding the effects. You can drop these onto the clips or empty slots too.
https://resolume.com/support/en/effects
They are also a great way to modify the looks of your existing media files.
