Wire Syncing Problem
fresnobob71
Post by fresnobob71 »
I have a simple patch that changes the image every beat. I put 4 clips with the same Wire patch on them and use Ableton synced with Link to trigger them every bar via MIDI randomly.
What I've noticed is a slight jitter as it changes clip. Is this expecting too much of Wire and Resolume or perhaps my machine is a bit slow, or is there something I can do to fix it?
My machine is a 2021 A15 Tuf with
Samsung SSD 970 EVO Plus 2TB,
32.0GB Dual-Channel DDR4 (15-19-19-44)
4095MB NVIDIA GeForce GTX 1650 SUPER (EVGA)
Here is one of the images it's a 1080px x 1080px png (the other 4 are the same).
--begin-wire-patch--
1543.3oc2Xk0iaaCD9uhgd1xf2G6a9rnnnIoMoMODunfRhxKajkb0wlcSv9euCk7Y1016QBBPBvBSw7wgb9luY3wWBhKxysw0th7pfK9vWBRKKVBMP8CJZpW0TGbY+f5BnGZ+.WNzAN3x65uEG6n3PGfi2OHsnobKJA7aoawBa4AvvG0bjCvQNJN5A3n2CGFsF3A3Davg1Aj7P.wj6iDljJaVGIBfub83dcYB3cW7A36k1ZSvEeIvzTeUAzWPP+fXSscQQ4svW1zTXzPeI1UYE2tzlW+NS4BaseLQkl73q5FStYoEZ8dWoE95ZaYkeJAPKM+q2tRXpb49VXHvrxT6GH5t67VtJtzspcI1ZpDW0pLysupyhuoHeQu+nwV0B.bfDXM3RcdGHHxlRhkQ5PRTDKjEYHgQIDYn1viTFNNwxvvXxbw17J6LWlsaJV2w5o.5Xowk00p.h8tbS1K1MUacSh2M+uFSlqF3TJQwgfZospHqod8vux5VbELaXjBTAexkTCiCqIHXjUlqseqWM0W0rLJeqS2Tttw017jNY..J2dS8qJRr+ZRWTKGZW4MOpUwTCoIQM0cc4VZVX8MpuckeM4culx310kIqw2EVxzFEWlpXwbVjfmJSvJEiFyPpnXseJc4U0f+0Yy0lxkCxQHbu0RXuGDUzjmTc.2w1m5fz5aBtPfQCjbJVRUDEl.c5i.BnSLmJHblpqevfwYlpNWAb2.oTnkDAOjJTzPFROJTMVoCYzgyFNcndHYDZeNG2Zgh3OBi8ZPiV3yiJxZ4xT3eBCB01UqCV2NQU0kltk9VeMpnHamilZxprdm8JWBH6gL107b+ciceN6xsRh2Vjk3Z4rsQ5+4ZWkKxmATW1XAiheVQwTokJL1TkVPRsJBkGESoVdDEyMI.zuGQQBd.BojJMRrNFxXnAXNhfjb.E8mvP3axL41SG.en7vW.0qH6XdJok4wRO0i4.SqIZgRtl8E5AHEVgkBh3bz+noSGFxlPUgpoS4gnoiFxFOZBZ3zouT5uaWvcdZMTwpozRR14q4MYYeE++.j865FXuW2TeZJmbeJOMq3S6sFZ+bW9hEJoV2kT.q0vDGrGZU2YZNU.ZC9ND6bP+O6kLlUXZM9RyMOAS6Q+XMrK+oXX.8ixvmU+sNyGiU7AcZNEBO3DprYSXfJiQgjb8LQnb1rgiFijSmLbz2ZUVmOr0mHqoziif0QMGG.5PE5ZIzdJfGP9rGaeuvzdg36oM1I5eeoY0IU6jm0ND7HDiZhRiiRwVofkDo0oVbTbZJWJPluW6PHILrhfI6sKAGApGESgTTlVfzT4OcaS7NS9GOYPj9TqXU4V.m+8IDk16RFmI6eyf8Cw8Y6oLqOm4zFaWw9inSn2WmfoZ0.MmfHBpPh2e+Lg.TGRJgQ7cebYhPoAwwP83PEY3nPMSKwBDkBmH4aRgFziX+rsW38QCk73gReTP2cuxykAuSR+Uxj9ahnqEfsRhGVk+KvUROoJm8rJUwRf6aEohUQZjxPiXVtfKgdjQvEKiPeetRBd.Sy8pF4tSTQThAHpRKQZlWlI9I7.sv5p8J7GOJxelmt5gIeN6A2mfhQb1VhGiv.yyjHtZS+mH2WhjPtOcbndxrQgnIyjJxH0jQZ9Kj3en8+qupz1xqta7e8Ia1018q7WZxqVUTV2aj0b5isJ91dQALRbOlUiYCvXFbKArVS1VYUqvCzLlTPwJJ+za.OdhZbHapPDpfBpgTDFOgIHv14ieoxZH22dvEEV+Be2qpVsor9TmSyCwt53H7KtMF+bS2YuUxXf4qO4s3uq+1xZGVy6rO1BfYkwG.CFew74+UEvtymO9pRG7yqysSJcWa6E162c4fMyxtE9OyZ.euLpXYz74+sm368mal64y+SaRu2VCko6MB7vtlym2192bYYU87.5Z46b97ptmnXvp7E9xrmsT7O9ErKeQlcoIeyR9rGz8G9RFTTebyp8rObyO7U6J+Kdzsb8B6FmeIECoBksTITjgfnatMHTA5yE9G9Fe3gQ9.TryuQR6c08WgweBX+ic09dI8C7+wBt7t69edrMsbC
--end-wire-patch--
tijnisfijn
Re: Wire Syncing Problem
Post by tijnisfijn »
Try to render your pngs as 1 frame DVX movies... that might help
