Feature Request: Multiple Workspaces to suit minimal or maximal setups
seethings
Post by seethings »
I've built out quite a nice setup utilizing my iPad as a secondary screen to house several panels that gives me quicker access to parameters I need. But there are times when I need a more minimal set up, using just my laptop. Compositions that were created with the secondary monitor in use require a bit of reconfiguration when i'm without it, thus I suggest Multiple Workspaces that are saved to the composition or global, similar to how Adobe has different panel layouts in Premier, Illustrator, etc. It's just an easily selectable interface preset. Adobe example attached.
Thank you!
-Tim
tijnisfijn
Re: Feature Request: Multiple Workspaces to suit minimal or maximal setups
Post by tijnisfijn »
thats already possible... under view there is layout.... there you can save different setups
seethings
Post by seethings »
Well. Thank you for pointing that out for me. It's been a feature for how long?
Cheers,
Tim
tijnisfijn
a long time... don't no how long... but for quit a view years
