Master Speed should affect Timeline Parameter Animation
Full Spectrum
Post by Full Spectrum »
As it says in the title, it would be nice if the various speed handles affected animation parameters as well. Things like animation envelopes and even auto pilots. I find that the master speed is a great way to skip through and quickly preview my composition, but if I have an auto pilot or envelope timed with the footage, I can't really use it.
Thanks.
Re: Master Speed should affect Timeline Parameter Animation
Params have a Clip position option you can use, then they will follow the clip timeline exactly, maybe that helps.
Full Spectrum
I suppose it can work for some cases! But more often than not I am using loops, since I work primarily with live music. Animations have to be independent.
