Input DMX, No Values seen in Resolume
b-mcg
Post by b-mcg »
New Resolume user here. I'm trying to drive Resolume from my lighting console and I'm having trouble getting getting Resolume to see my artnet channels.
When in Arena/Preferences/DMX, DMX INPUTS, it appears I'm only allowed to use "LUMIVERSE 1" but I'm already using Lumiverse 1 to output artnet to (Epix Strips). My question is; do I need to simply set the subnet and universe setting not being used to control my epix strips?
TIA,
Re: Input DMX, No Values seen in Resolume
You can have 4 input universes in Arena, any you can set their address in the preferences - DMX tab
If you click the small play button on the top right there, you should be seeing the incoming data.
Don't forget to set the network adapter at the bottom.
https://resolume.com/support/en/dmx-shortcuts
