Cant locate slices in Avenue
mikeprodj
Post by mikeprodj »
how come i dont see slices in effect tab when i search it wont show up also on the view tab it wont show me show slices i did create 2 slices in the advanced,am i doing something wrong? im using AVENUE thanks
Re: Cant locate slices in Avenue
Slice effects are Arena only.
mikeprodj
Post by mikeprodj »
If I’ll upgrade to ARENA will all my data(visuals) transfer there or I’ll have to do it all over again?
Arena will use a different Documents folder, but you can copy the Documents/Resolume Avenue over to Documents/Resolume Arena and that should just work for the settings and compositions.
