LED Pixel Bar 18x4w Patch Problem [Solved]
SammyDeluxeDo
Post by SammyDeluxeDo »
Hello everyone ;)
I would like to control an LED pixel bar with 76 channels using Resolume Arena. It has RGBW for each LED.
https://flash-butrym.pl/en_US/p/LED-BAR ... ection/709
However, I've encountered a problem:
The first two channels are dimmer and shutter, followed by the red, green, blue, and white channels for 18 LEDs, and at the end, there are 2 auto programs.
How should I set this up in the patch? Should I occupy the first two channels with a solid color in white so that they're always on and then start with the first LED from channel 3? It would be great if someone could help me with this.
I've already asked a few technician colleagues and searched forums, but unfortunately, I haven't found anything. Thank you so much :)
Re: LED Pixel Bar 18x4w Patch Problem
add two dummy channels at the start to the fixture
https://resolume.com/support/en/fixture ... y-channels
SammyDeluxeDo
Thank you for your reply ! So it looks like this correct ?
First Dummy is Dimmer: 255 (on)
Second Dummy is Shutter: 1 (off)
Last 2 Dummy are Sound and Function Modes
Yes, that seems to match with what you said about the fixture channels.
SammyDeluxeDo
I wanted to take this opportunity to thank you for your help. It's really great, everything works :idea:
Re: LED Pixel Bar 18x4w Patch Problem [Solved]
You're welcome ;)
