Beatlooper 1/16 not working
mowgli
Post by mowgli »
I've just noticed that the 1/16 Beatloopr doesn't work as expected. It plays the whole length of the clip at a slower speed than the clip is set to. All the other steps work normally.
I've tried on loads of different clips with the same result.
Re: Beatlooper 1/16 not working
What's the composition tempo you are using?
