Midi mapping issues about master speed and clip
pvppk
Post by pvppk »
Hi everyone
I don't speak very well English, I try to describe my problem accurately. :geek:
We all know the master speed can't control the clip effect parameters (for example I set a automation on clip rotation) , so I map the parameters to clip dashboard, then map the clip dashboard as a same knob with master speed, and try to control them as one, but it only happen when that clip has been selected. I tried to skip the dashboard, directly to the midi controller, it has same issue.
Is this an impossible move? or am I doing any wrong?
Thank you !
Re: Midi mapping issues about master speed and clip
Try BPM synced parameter automations, then control the composition tempo with Midi.
Or use effect clips instead of effects placed directly on the clips, that way you can keep an effect playing and switch clips separately.
https://resolume.com/support/en/effects#effect-clips
Or set the param automations to clip position, and then have the clips play in timeline.
