Chamsys Patch File
ceecrb1
Chamsys Patch File
Post by ceecrb1 »
Got bored. So for anyone who wants it...
Made patch files for ChamSys and Resolume for simple shows.
It's nothing more than 100 columns, Go, Back, Clear, Master Intensity and Master Volume.
Is one head number, 100 HTP element multi head element where each element number matches the column number in Resolume.
So if it were head number 72 and you wanted to fire off column 68, ChamSys syntax is: 72.68@FULL
All other attributes appear in BEAM page 1.
Locate is set to perform a GO... so easy to fire off in an emergency.
Resolume_Resolume_100ColsGoBackClearIntVol.zip
(7.22 KiB) Downloaded 522 times
ceecrb1
Re: Chamsys Patch File
Post by ceecrb1 »
So the wonderful members of my chamsys facebook group corrected me and told me about the TINY arrow that appears when you are in dmx mapping mode, so don't need channel per column......
attached is updated head file and resolume file
Resolume_Resolume_6ch Simple.zip
(1.9 KiB) Downloaded 469 times
