Envelope Relative to value
It would be great to have the envelope have a size parameter and a button to make it relative to the current value. Currently you apply a preset, and its absolute, but maybe you just need a bit of modulation from the value its already at, either a bit of noise, or fade in some noise/jitter, or just a gentle sine wave around the value you are at. A scale would let you 1 parameter control how much you want it to move, select all and scaling the points could work too, but I'd like both that and relative
rywolfday1
Re: Envelope Relative to value
Yeah wish that was editable on the fly in resolume for a long time.
here is a outboard solution:
https://vcvrack.com/
wavetick studio if on a mac is another option.
