hi
whats the best way to connect 12 displays ?
pc with 3 gpus ? (4 displays each) ?
i was thinking about RYZEN 7950X cuz it got 28 lanes
and using rtx4070 + 2x 4060 + nvme + 64GB RAM
the problem is that on all boards(that i checked) ,the 3rd pcie slot is 2x
is it a big issue ?
thanks in advance
x12 display setup
Re: x12 display setup
The way is to split the signal after its finished
So i.e. you output 1 4k Signal and split it into 4 times 1920x1080....
So you allready got 4 outs... Then it depends what your GPU can handle... or if you may can sacrifice some resolution and 1280x720 is maybe good enough...
https://resolume.com/support/en/lots-of-outputs
~Berlin~
~Berlin~
- Team Resolume
and https://www.datapath.co.uk/datapath-pro ... apath-fx4/ will definitely be your friend here. You can input one signal and split it into four..
So I would find a way to send out three signals from your PC. (I'm a Mac user so can't really tell you much about that part) And Let those go to three data pets and then you'll have your 12 screens.
Good luck. I hope this helps you out. If you have any more questions, don't be afraid to ask them here or in the slack channel.
