Wire transport keeps hiding
mowgli
Post by mowgli »
My Wire transport controls keep hiding themselves.
Every time I start up Wire I have to make them visible manually and often while I'm working they will disappear on their own.
tijnisfijn
Re: Wire transport keeps hiding
Post by tijnisfijn »
The transport controls are not visible, if there are no nodes that use the transport controls. Only when you drop in a node that uses them like transport time, then you will see the transport controls appear.
