More autopilot features
rawdesigns
Post by rawdesigns »
feature request to have auto pilot "play first clip" and "play last clip" in the layer. Right now you can only get these two options in the clip properties
tijnisfijn
Re: More autopilot features
Post by tijnisfijn »
hi.. We are busy with redesigning the autopilot feature... But it will probably take a few versions before we can release it. In the meantime... if you select the clips, auto pilot settings can be edited on the multi selection. Maybe that helps a bit...
