Trail of light effect
pette
Post by pette »
how can do the effect you can see in this video
at 32:32 ? there a "trail of lights" the appear and disappear
thanks
Re: Trail of light effect
It's a 1 hour video. Not watching this lol. Why not include a time stamp?
tijnisfijn
Post by tijnisfijn »
I think that you mean is something like this:
That's quite easy to achieve. I would start with a gradiant on layer 1. Then a transform afterwards put the parameters a bit like the picture I included but of course you can play around with this. ... And next, for a longer trail I would add a feedback source on layer 2 and play around with that one for the trail... You can also play around with the blend modes of layer 2. If you have this, then of course, you can always add some extra effects like a glow or may be a extra transform to rotate over the Y axis to get a bit more depth and of course mirroring will work very well. good luck. I hope this helps you out, and you'll make something nice. Don't be afraid to post your results. ;)
pette
Post by pette »
Hi! Thanks, it is very simple and it works!
Thanks this is what I want!
8-)
