FFT Input does not work when i use headphones
oddity
Post by oddity »
This feels like a weird situation.
I'm using Resolume on windows.
In Preferences -> Audio
I have both "Audio Output Device" and "Audio Input Device" set to "Primary Sound Driver".
Outside of resolume when I set my audio output to play through my desktop speakers (ie when I select the speakers as the sound output in windows), then in resolume FFT input works perfectly.
But if, outside of resolume, I change my audio output to my bluetooth headphones, then within resolume there is no FFT signal.
I have tried all combinations of different devices for "Audio Output Device" and "Audio Input Device" within resolume but nothing makes a difference.
I do have "Left & Right" selected for the "External Audio FFT Input" option.
It would make sense to me that I should be able to just leave the output and input device to "Primary sound driver"... I dont understand why Resolume can read the audio when windows sends it to one output but not to another.
Any thoughts on how to fix this?
mowgli
Re: FFT Input does not work when i use headphones
Post by mowgli »
It sounds like your sound input is your microphone, if you use headphones that won't work for obvious reasons.
You'll need an app to route audio internally
