Operations on multiple clips bugs Resolume 7.20.1
psychodalien
Post by psychodalien »
Hello!
I've encountered strange behavior when I create new Composition, drag some clips from Explorer to Resolume, selected them and tried to right click - Resize - Fit them. Some clips stretched to screen size instead of fit, some did it right. All clips are encoded in DXV, they have different resolution. I've selected clips and again set Resize - Fit a few more times and a few clips jumped between Stretch/Fit mode again. I ended setting up Fit mode on every clip one by one, then when I select all of them and choose Resize - Fit, they won't jump between Stretch/Fit mode as it was previously.
Moreover, I've set default video clip play mode to Play once&Hold in Preferences, imported the files, but only the first clip was set to this mode, the others left in Loop mode. I closed Resolume and did it once again - this time the first two clips were set to proper mode, others left in Loop.
PS Windows 10
Re: Operations on multiple clips bugs Resolume 7.20.1
Thanks for letting us know, looks like this broke somehwere along the way.
psychodalien
The problem with resizing multiple clips still exists in Resolume 7.21.2
