Since I have updated to 7.21.0 I have had the edit midi shortcuts menu take 2-3 minutes to open.
After the first time it seems to be more responsive and opens within 1-2 seconds.
It is the same on two different computers with the same composition and midi shortcuts.
Is there a reason why this is happening now?
Has anyone else experienced this?
Thanks.
Edit midi shortcuts 7.21.0 problem
tijnisfijn
- Team Resolume
Re: Edit midi shortcuts 7.21.0 problem
hi EMB,
Could you maybe sent your composition and your midi shortcut file (to mail@resolume.com) and tell us which controller you use so we can try to find the problem.
Thank you for reporting the problem and your help..
EBMCreative
Email sent
