I have had a weird and strange issue with alley for months and months now.
After I encode files with it and close the program it will never close on its own. It just sits in limbo until I goto the task manager and end task.
But if I only use it to view and not encode it closes immediately.
Any ideas of what is causing it to hang on close?
I'm running a core i9, 96gb ram, 4070ti, windows 11.
Alley
tijnisfijn
- Team Resolume
Re: Alley
So this is happening with multiple different versions and updates? Does this already happen if you encode only one files and close? Does it matter what kind encoding you pick? Is it the same for the DXV, Pro-Res and H264? Are you using the latest video drivers? Any more info you can give us would be helpful.
