Drives wont load
siliconmana
Drives wont load
Post by siliconmana »
Same problem l've had with earlier version trials l've downloaded.
On two different machines, same problem.
When l load Resolume, drives are not displayed, or cannot be accessed to load clips.
Sometimes rebooting software will help, though not always.
Please advise.
Siliconmana
Xp Pro, Asus A8N Sli-Premium, Athlon 64 bit 3000+ 1.81GHz, Geforce 6600GT, 1G DDR2 Ram
XP Home, Dell Inspiron 8500, 4-M CPU 2.4GHz, 1G Ram, Geforce 4200 Go
[Edited on 27-7-2006 by siliconmana]
siliconmana
Just did some testing. Spent an 1/2hr opening & closing v:2.3 &v:2.2.
Had a music cd in drive and kept loading that.
Removed it, then reloaded both versions, both tried to look for cd.
Also had 2 bot apps running in background, and msn.
Did a cold reboot and loaded both versions straight away.
This was on Asus/Athlon machine.
Why is it seeking the cd in dvd drive which has mp3's on it.
Still not clear why sometimes, even when nothing in drive, l am unable to access folders in root directory.
siliconmana
same on laptop if l have a dvd in drive, it tries to access that and wont see files in C drive. I have a trial version of 2.2 on laptop.
I'd really like to buy Resolume, though l need answers to these ongoing problems.
HELP!!
[Edited on 28-7-2006 by siliconmana]
you seem to have some software installed on all you computers that is causing this problem, i have just tried it with a dvd and then without like you describe but i can,t reproduce and confirm this.
siliconmana
Thats a shame, as its very annoying and l have used Resolume trials for some time now, always the same problem. :( So you havnt heard of anyone else having the same problem..mmn, dont know what it could be, that is on both machines. Would it be a d3d application? I use online Vr browsers. Other than that, l had problems with Nero directshow files, neaudio.ax etc, but deleted them now. lm not running any other software when l am running Resolume generally, and doesnt seem to make a diff on either machine even if l am. Still cant get to C drive unless l remove disk and reboot. Is there some way to run a debug log on it and send to you?
[Edited on 2-8-2006 by siliconmana]
Please try Resolume 2.4 beta and see if the problem persists, Resolume 2.4 bea can create a log file and we,d love to have a look at that. Here are instructions on how t activate logging:
http://www.resolume.com/forum/viewthread.php?tid=2572
gosub
Post by gosub »
did someone get to the bottom of this? i have just started experiencing the same problem with 2.4 and i have a gig tonight so i really am quite desperate for it to be resolved..
