Urgent Advice Needed: Additional GPU for Multi-Projector Setup
salahaddin
Post by salahaddin »
Dear Team,
I trust this message finds you well.
I am currently seeking urgent support and advice for a setup involving a small projection configuration with 4 projectors. I am in need of a computer with 4 output ports for the projectors and an additional port for a monitor.
I have constructed a system utilizing an RTX A4000 card, which, unfortunately, provides only 4 outputs. To address this limitation and accommodate the need for an additional port for the monitor, I am seeking recommendations for an additional GPU with suitable specifications.
Could someone please advise on the recommended GPU specifications that would fulfill this requirement?
Your prompt assistance and guidance on this matter would be greatly appreciated.
With regards,
Re: Urgent Advice Needed: Additional GPU for Multi-Projector Setup
What resolutions do you need for your outputs?
salahaddin
I need 1920x 1080 for each port.
the system has RTX A4000 GPU
can ID additional car RTX 1060 card.. ,
i will use all the four ports for projector On A4000 and GTX1060 for Monitor. Or Any alternative card
another setup i need all the four ports 3840 x 2160 .
i will use all the four ports for projector On A4000 and GTX 1060 for Monitor or Any alternative card
https://www.bhphotovideo.com/c/product/ ... mi_to.html
https://www.bhphotovideo.com/c/product/ ... _with.html
You could use any gpu and one of the boxes above to achieve what you're after.
If you are NOT planning on blending the 4 PJ's then you could add in another GPU as well but I would just use the AJA box and call it a day.
Hugo Biermann
Post by Hugo Biermann »
Simplest most reliable way to do it is with a 4k splicer. Only problem is the distance from the splicer to the projectors… You will be limited to 20m max DVI runs if you need the sync…
We stock these as solutions to these problems:
https://www.rgblink.com/x1pro-e.
One HDMI fibre run. Arena does the splice.
