Keyboard Shortcuts
Manwell
Keyboard Shortcuts
Post by Manwell »
I have been setting up custom keyboard shortcuts and have come across some difficulties. I have set a key to toggle between timeline and audio settings for the active layer but it doesn't affect the bpm button and I cant find a seperate shortcut for this. Its very annoying because I have to use the mouse to switch between timeline/audio and bpm and I want to avoid the mouse as much as possible. Also I have set 3 keys for the play modes of the active layer, loop, bounce and play once, but when in bpm mode the keys for loop and bounce don't work and again there doesn't seem to be any seperate shortcuts specifically for the bpm play modes. Am I missing something or is there a workaround for these problems? If not can these extra shortcuts be included in the non beta version?
yes these shortcuts are missing in the beta, we'll add them in the final 2.4 version.
Manwell
Post by Manwell »
Thanks for the reply. i cant wait for the final version its going to be incredible!
