Limit of playing Clips simultaniously (in different columns)?
luxundkelvin
Post by luxundkelvin »
Hello out there
i have a problem and no solution .
short explanation: we have programmed an interactive racegame in which 2 players can compete against each other on a skyscraper while cycling. each floor is illuminated L & R by a lamp when a certain distance has been travelled. in resolume we had created a layer per floor. each layer controls a lamp.
we have programmed it so that one more floor lights up the further you travel = one more clip is always played.
Example: clip 1 after 10m, clip 2 after 20m, clip 3 after 30m. and so on… on both columns same same. the commands for each clip comes via OSC.
unfortunately, after 24 simultaneously played clips or after 12 in columns 1 & 2 (a total of 24), the playback stops or the clip is no longer outputed.
is there a limit of 24 simultaneously played clips? the osc command arrives at clip 13 and it is activated but not played. i can also start a maximum of 12 clips in columns 1 and 2 at the same time manually using the mouse. is there a solution for this?
race is tomorrow evening! 🤯😇
thx for any help
Re: Limit of playing Clips simultaniously (in different columns)?
One layer can only play one clip. (two during a transition)
To play 24 clips at the same time, you'd need at least 24 layers.
