Changing which screen in outputting during a clip
thomaschurch
Post by thomaschurch »
Because of a weird stage setup, I need to change to different screen setups during a clip. Is it possible to do so using Clip position so that it is automated?
Re: Changing which screen in outputting during a clip
Clip position can be animated, and shortcut mapped, if your screen would be moving.
If it's a fadeout and fadein at the new position, you can use different slices also for positioning using the slice transform.
https://resolume.com/support/en/transfo ... -transform
