mirrored masks
alchemist
mirrored masks
Post by alchemist »
just incorporated a few custom masks into new resolume
the problem was, they came out vertically mirrored on the screen.
even the default resolume one was inverted.
they all look good as thumbnails in transparency menu, but when you apply them, they turn upside down.
I used regular, greyscale bitmaps.
I know its a minor bug, but its probably easy to fix too.
in 2.4 beta the transition/mask images were upside down, they look fine here. can you send me one of the bitmaps that appear mirrored?
