Arena 7.21.3 rev38686 hangs on startup
joejoe_sf
Post by joejoe_sf »
Hi there,
I've got an issue starting up Arena 7.21.3 on a Windows 10 PC. Version 5 runs without an issue, but a fresh install of version 7.21.3 rev38686 won't get past the "Initialize Application Framework" section of the splash screen... it just hangs there forever until I get the "Resolume Arena is not responding" OS dialog box. Same version of Wire opens just fine.
NVIDIA driver version 522.86 on an RTX8000.
I've tried deleting all previous folders in Documents, AppData, removing the application and re-installing, etc to no effect.
Any thoughts? Logfile is attached below-
Cheers,
jj
Code: Select all
Resolume Arena 7.21.3 38686 built 16 August 2024
Log started: 8 Oct 2024 1:27:04pm
[2024-10-08T13:27:04.040-07:00]   INFO: Logging has started
[2024-10-08T13:27:04.066-07:00]   INFO: Ensuring Nvidia profile correctness
[2024-10-08T13:27:04.257-07:00]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2024-10-08T13:27:04.257-07:00]   INFO: Nvidia profile setup finished successfully
[2024-10-08T13:27:04.351-07:00]   INFO: Initializing application. Command Line:
[2024-10-08T13:27:04.352-07:00]   INFO: Created TaskManager with 10 threads.
[2024-10-08T13:27:04.353-07:00]   INFO: Disable screen saver
[2024-10-08T13:27:04.373-07:00]   INFO: Initialise JuceResapiApp
[2024-10-08T13:27:04.374-07:00]   INFO: Initialise ResApi
[2024-10-08T13:27:04.374-07:00]   INFO: Initializing Resapi
[2024-10-08T13:27:04.374-07:00]   INFO:     Created ParamCollection
[2024-10-08T13:27:04.375-07:00]   INFO:     Created InputController
[2024-10-08T13:27:04.378-07:00]   INFO:     Created DeviceChangeDetector
[2024-10-08T13:27:04.378-07:00]   INFO:     Creating VideoFormatManager
[2024-10-08T13:27:04.379-07:00]   INFO:         Registering basic formats
[2024-10-08T13:27:04.379-07:00]   INFO:         Registered 4 formats
[2024-10-08T13:27:04.380-07:00]   INFO:     Created VideoFormatManager
[2024-10-08T13:27:04.383-07:00]   INFO:     Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2024-10-08T13:27:04.397-07:00]   INFO:     Trying to create DirectShow capture input device for: Anker PowerConf C200 (DirectShow_\\?\usb#vid_291a&pid_3369&mi_00#a&174eeb6&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global_Anker PowerConf C200)
[2024-10-08T13:27:04.549-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChA (DirectShow__Bluefish444 Capture Video C1ChA)
[2024-10-08T13:27:04.551-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChB (DirectShow__Bluefish444 Capture Video C1ChB)
[2024-10-08T13:27:04.552-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChC (DirectShow__Bluefish444 Capture Video C1ChC)
[2024-10-08T13:27:04.554-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChD (DirectShow__Bluefish444 Capture Video C1ChD)
[2024-10-08T13:27:04.556-07:00]   INFO:     Trying to create DirectShow capture input device for: OBS-Camera (DirectShow__OBS-Camera)
[2024-10-08T13:27:04.568-07:00]   INFO:     Trying to create DirectShow capture input device for: NotchCam (DirectShow__NotchCam)
[2024-10-08T13:27:04.575-07:00]   INFO:     Creating DisplayCollection
[2024-10-08T13:27:04.582-07:00]   INFO:     Created DisplayCollection
[2024-10-08T13:27:04.583-07:00]   INFO: Successfully setup Resapi.
[2024-10-08T13:27:04.583-07:00]   INFO: Initializing Resapi graphics
[2024-10-08T13:27:04.584-07:00]   INFO:     First time OpenGL usage, initializing extensions.
[2024-10-08T13:27:04.584-07:00]   INFO:     Registering window class.
[2024-10-08T13:27:04.584-07:00]   INFO:     Successfully registered window class.
Re: Arena 7.21.3 rev38686 hangs on startup
Update drivers for the dedicated and integrated GPUs.
joejoe_sf
Post by joejoe_sf »
Copy that, thanks, didn't realize I'd turned off the auto update.
I tried upgrading to Nvidia Studio driver 561.09, and the standard WHQL 553.09 and had the same result as before... Each time after a driver install it asked me to recreate and restart the NVIDIA profile, but then got to the same "initalizing application framework" and hung. Integrated GPU is disabled in BIOS so it's only the one display device showing in Windows.
Next thoughts? and thank you!
Code: Select all
Log started: 9 Oct 2024 9:20:15am
[2024-10-09T09:20:15.328-07:00]   INFO: Logging has started
[2024-10-09T09:20:15.339-07:00]   INFO: Ensuring Nvidia profile correctness
[2024-10-09T09:20:15.588-07:00]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2024-10-09T09:20:15.588-07:00]   INFO: Nvidia profile setup finished successfully
[2024-10-09T09:20:15.656-07:00]   INFO: Initializing application. Command Line:
[2024-10-09T09:20:15.657-07:00]   INFO: Created TaskManager with 10 threads.
[2024-10-09T09:20:15.658-07:00]   INFO: Disable screen saver
[2024-10-09T09:20:15.679-07:00]   INFO: Initialise JuceResapiApp
[2024-10-09T09:20:15.680-07:00]   INFO: Initialise ResApi
[2024-10-09T09:20:15.680-07:00]   INFO: Initializing Resapi
[2024-10-09T09:20:15.681-07:00]   INFO:     Created ParamCollection
[2024-10-09T09:20:15.681-07:00]   INFO:     Created InputController
[2024-10-09T09:20:15.683-07:00]   INFO:     Created DeviceChangeDetector
[2024-10-09T09:20:15.683-07:00]   INFO:     Creating VideoFormatManager
[2024-10-09T09:20:15.684-07:00]   INFO:         Registering basic formats
[2024-10-09T09:20:15.685-07:00]   INFO:         Registered 4 formats
[2024-10-09T09:20:15.685-07:00]   INFO:     Created VideoFormatManager
[2024-10-09T09:20:15.689-07:00]   INFO:     Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2024-10-09T09:20:15.708-07:00]   INFO:     Trying to create DirectShow capture input device for: Anker PowerConf C200 (DirectShow_\\?\usb#vid_291a&pid_3369&mi_00#a&174eeb6&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global_Anker PowerConf C200)
[2024-10-09T09:20:15.882-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChA (DirectShow__Bluefish444 Capture Video C1ChA)
[2024-10-09T09:20:15.884-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChB (DirectShow__Bluefish444 Capture Video C1ChB)
[2024-10-09T09:20:15.886-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChC (DirectShow__Bluefish444 Capture Video C1ChC)
[2024-10-09T09:20:15.888-07:00]   INFO:     Trying to create DirectShow capture input device for: Bluefish444 Capture Video C1ChD (DirectShow__Bluefish444 Capture Video C1ChD)
[2024-10-09T09:20:15.890-07:00]   INFO:     Trying to create DirectShow capture input device for: OBS-Camera (DirectShow__OBS-Camera)
[2024-10-09T09:20:15.962-07:00]   INFO:     Trying to create DirectShow capture input device for: NotchCam (DirectShow__NotchCam)
[2024-10-09T09:20:15.997-07:00]   INFO:     Creating DisplayCollection
[2024-10-09T09:20:16.002-07:00]   INFO:     Created DisplayCollection
[2024-10-09T09:20:16.002-07:00]   INFO: Successfully setup Resapi.
[2024-10-09T09:20:16.003-07:00]   INFO: Initializing Resapi graphics
[2024-10-09T09:20:16.003-07:00]   INFO:     First time OpenGL usage, initializing extensions.
[2024-10-09T09:20:16.004-07:00]   INFO:     Registering window class.
[2024-10-09T09:20:16.004-07:00]   INFO:     Successfully registered window class.
Cheers,
jj
Try enabling the integrated gpu, and updating it'a drivers also.
joejoe_sf
Post by joejoe_sf »
Hi again Zoltan,
Thanks- I'm running a Ryzen 5, so it doesn't have an integrated GPU. The motherboard video options don't even show up in the BIOS with a Ryzen installed.
Cheers,
jj
Lots of Ryzen 5s have integrated GPU.
Which exact CPU is it?
If you do a clean driver re-install, and choose not to load the nvidia profile, does Resolume start then?
