justify colomn position
SystemD
Post by SystemD »
Hello
I use resolume in many theater shows. For the most part, I trigger in osc columns. However, there is an option missing that would be very useful to improve my workflow. Beyond a certain number of clips, it is no longer possible to view the following one.
I would like to have the possibility to fix the triggered column in osc in the center of the screen. A bit like for text, when you want to justify it to the right, the center or the left.
Would this be possible in a future update?
Thank you
Re: justify colomn position
enabling Update clip panel on external trigger, and Scroll layers and clips into view in the general preferences should help a bit
If your app supports multiple messages, you can also use clip select messages to have the deck scroll to a specific clip position.
