Custom OSC input ip address?
rayg006
Post by rayg006 »
Hi there, just wondering why is there no option for a custom input ip address in the OSC preferences and be able to enter an address of 127.0.0.1 or a secondary network port if we also have a connection to the one automatically assigned?
This would allow local Companion app to control via Streamdeck instead of using third party or a secondary pc and can still use network ports for other things.
Looking forward to thoughts
Christoph
Re: Custom OSC input ip address?
Post by Christoph »
In the preferences you see the first active IP address, but Resolume should listen on all your IP addresses, including 127.0.0.1. Does this not work for you?
