Hi Everybody,
So my first post here is about not one but several problems with a lenovo PX workstation,
which we have bought because more PCI express Lanes.
We were fully aware that the second socket is more like a glorified southbridge,
but still went with it as one socket alone should provide enough power.
It was running well while testing with 4x4K BM SDI Inputs, and 3x4K out & GUI.
With a Windows update sometime 06/2024 we started to get performance Issues,
and the System starts filling RAM, and after 4-6 hours framerates, which for reasons unknown are now mostly below 50 start to drop to 4-6 frames.
Any ideas regarding this?
DXdiag attached:
System Information
Time of this report: 10/22/2024, 15:13:28
Machine name: DESKTOP-GLEKKM0
Machine Id: {3CF58229-DA78-41C7-82DE-2C8C8B7E5F8D}
Operating System: Windows 10 Pro for Workstations 64-bit (10.0, Build 19045) (19041.vb_release.191206-1406)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 30EVCTO1WW
BIOS: S09KT18A (type: UEFI)
Processor: Intel(R) Xeon(R) Silver 4410T (40 CPUs), ~2.7GHz
Memory: 262144MB RAM
Available OS Memory: 261542MB RAM
Page File: 11066MB used, 289388MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 192 DPI (200 percent)
System DPI Setting: 192 DPI (200 percent)
DWM DPI Scaling: UnKnown
Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.0.8
DxDiag Version: 10.00.19041.4957 64bit Unicode
Problems with Dual Socket Lenovo Workstation
Re: Problems with Dual Socket Lenovo Workstation
Are you using other capture sources too, or outputs with the BMD?
We're working on some memory issues related to those.
eliwieland
Good Morning Zoltán,
Regarding your question:
No, we do not.
As you are speaking about memory, may be this
Helps:
We hava made a .dmp file when Resolume was
@12 fps & using about 50Gigs of RAM, still gobbling up more.
Further we have been in Contact with BM,
When temporary all input cards in PX machines failed with Desktop Video 14.2, which we recovered on one machine.
Also there is an already escalated case with Lenovo, which you are more than welcome to pitch in, as i think there may something to be learned by
every party involved
Elias
No, we do not.
Helps:
Elias
So, all your outputs go from the GPU directly?
Do you see a steady increase in RAM usage right from the app start, or loading a specific deck?
eliwieland
Yes, they do.
As it happens RAM goes steadily up,
The composition initially takes about 12G,
And at one point got to 50, took about 72hours.
But:
The latest version seems to be running stable
Over time.
Though still with abysimal performance.
Question regarding this:
If overall RAM speed & bandwith is fine,
Is there a difference between single / multichannel?
Thanks,
Elias
But:
Over time.
Thanks,
Elias
12GB composition load, hmm,
Can you share the composition here, or via mail@resolume.com?
Could you please also send us the Resolume log file via the feedback tab in preferences?
eliwieland
Hi Zoltàn,
Sorry for the late reply, its a 2 hour travel to the venue where the machines are located.
I have sent the Feedback and log, please find the composition attached.
Thanks,
Elias
Thanks,
Elias
- Attachments
ENTRA Template (11.24).avc- (863.77 KiB) Downloaded 774 times
eliwieland
Addendum:
As the machines where running with only one channel of RAM Populated, today i made one out of two, what a wonder, contrary to what lenovo is saying there is 15-25 fps to be gained.
The logs i sent earlier are with 4 of 8 channels populated.
Sounds good,
So the Memory usage is now stable with the latest release?
