Color range settings not saving
MesmerizeATX
Post by MesmerizeATX »
I am running 8 outputs out of my decklink card and the frame rates were dropping over time and found out that after I changed the color range setting to Full RGB on all my outputs my frame rates were back up.
For some reason my settings on color range are not being saved and I have to go back in there and change it back.
I am also having another issue with the decklink cards not being seen on boot up and I have to restart the computer in order for it to see the outputs so maybe it has something to do with that.
IDK but looking for guidance here.
Christoph
Re: Color range settings not saving
Post by Christoph »
We worked on some fixed for issues with a memory leak with DeckLink cards and with the color range settings not saved correctly, these should be fixed in the next release.
Can't say if that will fix the discovery issue that you are describing though.
