Resolume 7.22 Release | Column Power ❤️ Autopilot Improvements 💥 LUTs 🌈 Wire Resources
Column Power
Resolume 7.22 is giving columns a powerful upgrade. You can now select, move, duplicate, and remove multiple columns. Selecting a column no longer triggers that column; instead, you use the column play button to trigger columns. This way, columns behave much more like clips. These buttons can be set to large or small in the View menu. The column trigger button shows either a play button when that column contains clips or a stop icon when there are no clips in that column, indicating that when you trigger that column, all playing clips will stop. Because columns are more like clips now, columns now also have beat snap settings, just like clips. But not only have columns received an upgrade, you can now drag and drop multiple clips, and it's now very clearly previewed where these clips will be placed when dragging.
Trigger next & previous column buttons now skip empty columns. This is an important change to be aware of when you use this. Now that triggering and selecting columns is the same as clips they also behave consistently so triggering next & previous column now skips empty columns just like empty clips have always been skipped by the autopilot and next & previous buttons. If you want to make a column that displays nothing now it needs to have a transparant or blank clip. You can now easily create a blank by right-clicking a clip and selecting Insert Blank.
Note that the Arena API has been updated accordingly. Now that columns behave similar to clips they will send out their connected state in the same way. Please make sure to update your code according the the API documentation.
The autopilot jumped, hit a mystery block, and ate all the power-up shrooms!
There is now a new autopilot for columns! On the group and composition panels, you can now set autopilot options for the columns. You can have it jump through columns after a certain time or number of beats, it can look for the longest, shortest, top or bottom clip in the column to advance to the next. Or it can look for clips ending in a certain (master) layer and then progress to the next column. The layer autopilot also has these new timing options, so it can also advance to the next clip after a certain time or number of beats.
These new autopilots allow for powerful and complex show programming.
To make sure you're not getting lost in the automation sea, we've added countdown dials on the clip thumbnails. These dials turn into countdown pies when in BPM sync mode. This way, you can already see which next clip or column is going to be triggered by the autopilot. These pies also replace the bars that were previously used to indicate beat snapping.
Global Clock
The BPM clock can now act as a global clock that can be paused and stopped.
This means that when the clock is paused, all transports, including timeline animations, will be paused.
If you prefer the old behaviour, you can configure it in the Composition menu. Global Transport can be set to BPM Clock and Timeline or BPM Sync only. Your existing compositions will have the Global Transport option set to BPM Clock Only, so it behaves like before. New compositions will, by default, be set to BPM Clock and Timeline. Give this a try; we think this is very powerful to pause (almost) everything with one click. There is now also a stop button on the global transport; this stops and rewinds all timeline and BPM animations and ejects all playing clips.
Hide Speed Sliders
As requested by many of you, we have added an option under the View menu to hide the layer, group, and master speed sliders. Not everyone uses this during their shows, and this way, you're less likely to accidentally change the playback speed of your clips.
LUT's Go!
Resolume Arena, Avenue, and Wire now support LUTs. LUTs are used in the video industry to quickly color grade content.
Resolume Arena and Avenue now ship with a LUT effect, which is used to apply LUTs to your content. Resolume Wire comes with the LUT 3D In, LUT, and LUT 3D Resource nodes, which are used to build your own LUT-based patches. Resolume supports the .cube container for LUTs and is shipped with 10 LUTs for your color grading needs. You'll find these LUTs in Avenue & Arena in the drives dropdown on the file browser.
Video Bumper Blend Mode
Arena and Avenue got a new blend mode called Video Bumper. This blend mode allows you to load a video and use it as a bumper while transitioning to a new clip. This mixer is made using the new resource type in Resolume Wire. Now that were mentioning those new types....
Resource Types
Time to get resourceful with Wire! The new resource types allow you to create patches that load external images, LUTs, and videos.  On the Arena/Avenue side, the user can simply drag and drop or load resources into their work.
Additionally, you can add options to your resource input nodes. This allows for easy switching between predefined resources.
Wire QOL Updates
You can now rename and recolour multiple nodes at the same time on the node panel.
Wire now supports navigation through the nodes with arrow keys, allowing you to quickly switch between neighbouring nodes. For the real power users, we've added the option to edit multiple components of Float2, Float3, and Float4 inputs. Hold down the Shift key and drag the input boxes to increase or decrease all components of the Float type.
Wire 7.22.9 Hot Fix
#23393 Wire crashes exporting video
Arena & Avenue 7.22.8 Hot Fix
#23271 Shutdown crashes with some compositions
#23330 Moving layer out of group doesn't update layer view
#23334 Duplicated columns have default thumbnails
Wire 7.22.8 Hot Fix
#23265 Editing ISF loses parameters
Arena & Avenue & Wire 7.22.7 Hot Fix
- #23309 Dongle registration broken on macOS with 7.22.6
Arena & Avenue 7.22.6 Hot Fix
- #23202 Recording on clip trigger does not start if there was already a clip playing in layer
- #23219 OSC Shortcut does not work (initially)
- #23264 Removing last column(s) keeps that column(s) greyed out
- #20744 Recording in h264 not working on macOS
Wire 7.22.6 Hot Fix
- #23225 ISF with still image input crashes Arena
- #23234 Texture In -> Unpack crashes Wire
- #23245 2D render node allows for negative entries - throws errors
- #23247 Cord going to Nirvana
Arena & Avenue 7.22.5 Hot Fix
- 14855 ProRes playback shifts colors a bit
- 18928 Unavailable Clip menu items should show inactive for clip playing from other deck
- 22880 Fixture for amber/white temperature RGB3
- 22943 Trying to add audio effect from preset to composition not working
- 22954 Column play buttons can show wrong state
- 22988 Composition column play icon not green if only clips in groups are playing
- 22965 Empty column MIDI output incorrect
- 23006 Transitions sometimes not executed
- 23064 Don't trigger column 1 with DMX value 0 on connectSpecificColumn
- 23065 Deselect source clip(s) and select new clip(s) after duplicating
- 23123 Select pasted clip(s)
- 23125 Select new column(s) on column duplicate/copy
Wire 7.22.5 Hot Fix
- 22975 Creating a Polar node from a collection of Shape2D Crashes Wire
- 23009 OSC in should reach all active patches
- 23083 Don't show Display output in OSC/Midi Out nodes
Arena & Avenue 7.22.4 Hot Fix
This update further improves handling of compositions with a lot of layers and columns. It uses less memory, loading and closing compositions with a lot of clips is now faster.
- 22673 Inconsistent menu options with multi-selection of clips and empty slots
- 22785 Column play button not always showing when column contains persistent clips
- 22794 Can't drag original clip off from persistent clip
- 22814 Files panel should show video codec too
Arena & Avenue 7.22.3 Hot Fix
- #22702 Composition with a lot of layers and columns can take very long to load and close
- #22713 High memory usage in 7.22
- #22732 MIDI messages can pile up an cause latency with clip transitions
- #22763 BPM-synced clips ignore "Active Layer" Clip Target setting when Beat Snap is enabled
- #22764 Blend Mode Changes for Multiple Clips Don't Apply Properly or Show Parameters
- #22767 AV clips with beat snap can start frozen for some beats
- #22768 Group solo makes composition blackout
- #22690 Transform widget sometimes misbehaves when monitor is undocked from main window
Wire 7.22.3 Hot Fix
- #22766 Texture 2d Channel Causes Monitor Display Issues
Arena & Avenue 7.22.2 Hot Fix List
- #22739 Low framerates with very big compositions on 7.22
- #22716 Arena sometimes crashes with older composition
- #22722 Crash dropping file from Finder to Render panel
- #22723 Midi shortcut feedback / clip trigger state sometimes not sending out deck switch
- #22724 Deck switch should select first column in new deck
- #22743 MIDI controller button does not light up when you drag a file to an empty clip that is midi mapped
- #22703 Autopilot section should be folded by default on clip panel
- #22709 Clip multiselect lost transform effect section delimiter
Wire 7.22.2 Hot Fix List
- #19844 Snapshot functionality does not adhere to node resolution
- #22726 Some patches with resources didn't work in 7.22.
Arena & Avenue 7.22.1 Hot Fix List
- #22695 Clip Transition can cause unresponsive user interface
- #22689 Auto pilot Clip loop not loading correctly
- #22692 Edit parameters from multi-selection not working
- #22691 Scroll layers and clips into view no worky using mouse
- #22693 Clip transport indicator on layers is gone
- #22694 Midi mapping for clips with Selected Layer not working
Arena & Avenue 7.22.0 Fix List
- #6938 ArtNet VSync
- #14453 Mapping the same MIDI CCs multiple times can make Resolume lag a lot
- #17245 Glitch triggering Syphon source
- #17946 Undoing deletion of persistent clip creates layered copies of clip
- #19564 Dashboard dial still linked after removing audio effect
- #20248 Weird behaviour when setting clip to persistent, setting it back to non-persistent, undoing that and then redoing that
- #20305 Param animation to 'Clip position' plays wrong value on clip trigger
- #20927 HSBA param update in FFGL no worky
- #20993 Update AJA SDK
- #21302 Memory leak with Ugreen capture card
- #21599 Crash changing AJA buffer size
- #21817 BlackMagic Decklink output set to SMPTE color format leaks memory
- #21854 Color range setting from capture card not saved with advanced output preset
- #22216 Iphone camera source has the format selection empty
- #21350 REST-API add endpoints to change parameter values by ID
- #21417 REST-API update effect names when renaming
- #21557 REST-API Clear clip through websocket
- #21609 Handling of URL GET params in the API server
- #21376 Recording no worky with japanese paths
- #21503 Group solo doesn't respond properly when layer in group is in transition
- #21506 Group Solo has no "selected Group" midi or keyboard shortcuts
- #21507 Layer Solo has no targets in midi or keyboard shortcuts
- #21596 Grid effect not working properly on vertical aspect
- #21662 Blend mode parameter doesn't apply mixer when changed through midi
- #21890 Original clip drag from overlapping persistent clip is broken
- #21968 Invert stripes not working any more in Stripper effect
- #21974 Slice refiner crashes when switching param settings
- #22004 Arena crashes when you rename a playing Wire patch and rename it back
- #22377 Video plays back with malformed pixels
Wire 7.22.0 Fix List
- #16419 Navigate to other nodes with the arrow keys
- #19941 Crash/ error when trying to add ISF to an example/documentation patch
- #20665 Prores 4444 export broken in Wire
- #20849 Forking a patch should also fork presets
- #21017 Wire mixer with same name overrides defaults setting
- #21560 Random node trigger should not be main inlet but the first inlet so it's more visible
- #21584 Delay node with single channel texture input leaks vram
- #21683 Wire presets aren't upgraded, but they should be
- #21713 ISF orientation in Wire different than on ISF site
- #21744 Start editing a selected comment node by pressing tab
- #21958 Some patches with ISF crash Arena when loading them
- #22346 Static goes black if time is too high
- #22380 Write program change sends Program number to Channel, and vice versa
Re: Resolume 7.22 Release | Column Power ❤️ Autopilot Improvements 💥 LUTs 🌈 Wire Resources
WOW!!!! Simply WOW...
I am so happy that I renewed my licenses on Black Friday. Nobody could have seen that strategically timed blast of an update coming! :P
best wishes
SeanBannister
Post by SeanBannister »
So many great usability improvments, this is exactly what we need!!! Noticed the new play pause stop buttons are mappable... would sure be nice if the Ableton Link button right next to them was as well ;)
cat
Post by cat »
Transitions work with autopilot too, is this new to this release and I just haven't tried it recently, anyway, thank you!
jim
Post by jim »
the documentation & videos for this version has are really good.
Fxcu CRX
Post by Fxcu CRX »
GREAT UPDATE!. i was waiting so much the Speed Sliders HIDE. it was so easy to mess it up in a corporative event! :lol:
manymanyhaha
Post by manymanyhaha »
Thank you for the Autopilot Improvements. Was doing midi workarounds to get the same functionality but this is simpler, works great.
live stream of music catalog to Resolume youtube.com/@manymanyhaha/live
Frischvergiftung
Post by Frischvergiftung »
I wish you guys would run Adobe :))) So many tidbits that just show that you listen to your users.
Full Spectrum
Post by Full Spectrum »
Wouldn't it make sense to have it also skip columns which only contain clips which are set to "ignore column trigger"? So that certain columns can exist only for clips that autopilot travels to, which an operator would skip over. Of course you can shove all autopilot stuff to the back and jump to it, but that becomes very hard to keep straight in your head.
And/or being able to flag a column as a skip would allow an operator to actually have a sequenced cue deck, a huge boon as it would no longer necessitate an external controller like qlab or (sorry) Pálffy Zoltán's Linear OSC Controller.
Either way, great improvements!
francoe
Post by francoe »
Downloads enumerate an undocumented 22.4 version . It's a fake? :?
