more control over speed parameters on effects/sources
volumetrisch
Post by volumetrisch »
Bug: If some effect/source parameter is set to timeline, it is neither affected by composition/group master speed anymore?! :evil:
(On top of that speed parameter on parameters can not be linked to dashboard - would be a nice feature)
Christoph
Re: timeline parameters on effects and sources broken
Post by Christoph »
I might misunderstand your report, but which Resolume version did link parameter speed sliders to composition/group speed sliders?
volumetrisch
well maybe it never was a feature my bad... but it would be very nice to have some form of global control over source/effect parameter speed on top of using bpm, e.g. composition/group speed affecting also timeline parameters or binding speed parameters to dashboard. :D
(yes its possible to bind every single one to some midi input but that is a bit complicated but works for me now ;) )
well just noticed +- buttons for speed on bpm parameters are bugged for sure:
"-" does nothing or sets it from value 1 to 2 and then its stuck
"+" sets it from value 1 to 2 and then its stuck
Christoph
Re: more control over speed parameters on effects/sources
Post by Christoph »
Yeah this gets complicated quickly when parameter animation options get their own parameter animations, but I can see where this could be useful with the dashboard or linked to the global speed for example.
Regarding the +/- spinners this is a known issue and will be fixed in 7.23!
volumetrisch wrote: Tue Dec 17, 2024 17:15 Bug: If some effect/source parameter is set to timeline, it is neither affected by composition/group master speed anymore?! :evil:
Timeline parameters were never affected by the composition speed slider.
Composition speed only affected the clip playback speed in timeline mode.
BPM synced parameters follow the composition tempo though.
Also you can link a parameter to clip position, to get indirect control via comp speed.
