Hello
I used to use a webpresenter HD.
Every once in a while the source clip would freeze.
The only way to get it working was to reboot resolume.
Now with the atem mini pro the source is freezing a few hours in and to reboot 10 times a night is not feasible to do.
Does anyone know how to get the capture to start capturing again and not be on a frozen frame?
This hapens to all clips using that source and any new clips using that source.
I hope there is a reasonable fix to this.
Arena 7.21.?
Win 11 24h2
Thanks.
Atem mini pro
EBMCreative
Re: Atem mini pro
I have found a temporary solution.
I am using ndi tools to do a screen capture and then using ndi in resolume to broadcast.
No freezing issues.
But I would like to see if there is a fix.
So many background processes running is not healthy. Currently my tray is at almost 20 programs now.
No freezing issues.
EBMCreative
Re: Atem mini pro
This solution did not work.
NDI was making resolume crash every few minutes and didn't allow for a crash report to be sent.
