Color picker
florent522
Color picker
Post by florent522 »
Hello!
I'm new to Resolume and i try to pick dominance color from the composition to use for led bar
I see we can pick a color but not automatically
I asked the question in the forum but my post will never approve?
Thank your for your help!
tijnisfijn
Re: Color picker
Post by tijnisfijn »
While I don't know if this is exactly what you are looking for this plug-in will automatically colorize everything according to the dominant color of your video. I hope this helps you out. You can just throw it onto arena so it will install and then you can find it in the effects panel under wire effects. have fun with it.
AutoTone.wired
(290.07 KiB) Downloaded 109 times
