Envelopes dont get undone when deleted
cat
Post by cat »
I keep accidentally right clicking on a envelope (thinking it will fold it up) but it deletes it, ok I can learn that eventually, but undoing it doesn't do anything, so you have recreate again
cat
Re: Envelopes dont get undone when deleted
Post by cat »
Also when working with envelopes on things like position scale, the slider is way too big, it needs modifiers to change step size, min is -32000 to max 32000 so one step of the drag is about 500. The number should also be dragable not just the +/- buttons IMO
cat
Post by cat »
Dragging left on pos etc also gets truncated by the edge of the screen, if you have your controls docked left as I have, and so you can only drag a small amount before having to release and click the buttons again
cat wrote: Wed Feb 19, 2025 17:20 Also when working with envelopes on things like position scale, the slider is way too big, it needs modifiers to change step size, min is -32000 to max 32000 so one step of the drag is about 500. The number should also be dragable not just the +/- buttons IMO
That's based on the GPU supported texture size, you could move a texture within those bounds.
Right click on parameters reset the parameter to defaults. Undo seems to work fine for me to restore the envelope and param state. Are you on the latest release?
Envelope has a fold up button you can use to minimize it:
Képernyőfotó 2025-02-27 - 15.38.29.png (14.23 KiB) Viewed 7329 times
cat wrote: Wed Feb 19, 2025 17:27 Dragging left on pos etc also gets truncated by the edge of the screen, if you have your controls docked left as I have, and so you can only drag a small amount before having to release and click the buttons again
Draging is based on mouse movement, you can't drag your mouse off the screen.
