behaviour issue when swapping blend modes
mowgli
Post by mowgli »
When changing the blend mode of a clip, the entire clip panel scrolls to its top, often moving the blend mode selector out of view. This is not the case with any other settings, and it causes friction as trying out different blend modes requires constant scrolling of the blend-mode setting back into view.
tijnisfijn
Re: behaviour issue when swapping blend modes
Post by tijnisfijn »
Do you mean that you're setting different blend mode through a midi controller?
tijnisfijn
Thanks for reporting this, I make a issue.
