Selected part of clip is lost
mowgli
Post by mowgli »
If you have an audio clip and use the in-out points to select an area and then try to combine this with a visual clip by shift-dropping, the in-out points of the audio clip get reset.
I've tried dropping the audio on the visual and vice versa to no avail.
Re: Selected part of clip is lost
We're making some improvements in this regard
