Clip render problems
mowgli
Post by mowgli »
I'm trying to render an AV clip with a wave and a Wire source on it. Some parameters are animated to "clip position" with custom envelopes.
Everything works as expected if I play it from within Resolume, but if I render the clip, the parameters animated with clip position envelopes don't correspond with anything that I can make any sense out of, and all the animation I've created is not in sync with anything.
Re: Clip render problems
Was this an AV clip with a different Video track, which you replaced with your source?
mowgli
Post by mowgli »
No, it's a .wav with a source.
It's not the entire wav though. I selected an area with the in-out brackets.
Interesting, I was able to break the render with an AV import, replacing the video source.
We'll see what we can do.
