Hi!
I've stumbled upon a problem with recording in resolume. Ever time im trying to record (composition/layers/groups -video), recording stops immediately. I was looking for an answer on the forum but I could not find any. Im running 7.22.5 version and i have over 400 GB of free space on my SSD. Last time changing the resolution of composition to 1920x1080 and back again helped but now it's not working. The resolution i mostly use is around 2304x768.
During the work my processor is used in like 30%. Has anyone had similar problem?
11th Gen Intel(R) Core(TM) i7-11700F @ 2.50GHz 2.50 GHz
ASrock H510M-HDV/M.2 se
32.0 GB
NVIDIA GeForce RTX4070
Recording issue arena 7
tijnisfijn
- Team Resolume
Re: Recording issue arena 7
Oh, that's not nice to hear. Are you trying to record in H264 or in DXV. Could you try if it works if you pick a other compression? That would be good to find the problem.
Yes, I've tried every preset possible.
How much free RAM do you have when running your usual apps and Resolume?
