PAL or NTSC?
cityanimal
PAL or NTSC?
Post by cityanimal »
I am evaluating Resolume for a performance project. I have been testing v. 2.4 and liking what I find. I see that the Resolume demo footage and footage I have recorded in Resolume are both PAL. My live cam is NTSC.
Can Resolume operate in a NTSC mode? If not I would imagine I am placing greater processing demands on my laptop when using a live cam which seems to result in jerkier recorded mixes.
Also can Resolume display wide screen footage? If so what custom setting does one use when preparing clips - 320 x 240 & 640 x 480
are not widescreen modes.
Charles
Resolume can output any resolution that you can set your second output display to. If you use ATI Omega drivers you can set the output to many different and 'weird' resolutions including PAL or NTSC.
http://www.omegadrivers.net/ati/win2k_xp.php
