Dongle not working after Sequoia upgrade
alanpower
Post by alanpower »
I've recently upgraded my M3 Mac to Sequoia 15.0.1.
Since this upgrade, the dongle has no longer worked. The system recognizes the USB key that can be read, but the watermark on my output is still displayed.
The privacy and Security options for the Arena app have been checked: Arena has the right to access the removable volumes.
I'm gonna install Arena on another pre-Sequoia Mac, just to be sure the problem is on my Mac only.
After that, is there any other test to do?
Thank you all.
alanpower
Re: Dongle not working after Sequoia upgrade
Post by alanpower »
I've done the test on another Mac (Sequoia 15.4).
Same problem, so the dongle has a problem.
What can I do?
thanks folks!
We're preparing a fix for osx related dongle issues with 7.22.6, meanwhile you can downgrade to 7.22.5 from the bottom of our download page
