FX Top layer blending issue.
Bassindaniel
Post by Bassindaniel »
Hello everyone,
I’m encountering an unexpected behavior with layer blending in Resolume Arena.
I have a top layer set to zero saturation and full opacity, but it doesn’t fully affect the layers beneath it unless those layers are at 100% opacity.
I expected the top layer to fully influence everything below it - similar to how a solid white layer would impact all layers beneath.
Please advice. Daniel.
tijnisfijn
Re: FX Top layer blending issue.
Post by tijnisfijn »
What blend mode are you using?
Bassindaniel
Alpha. Always.
zero saturation?
How is that set up?
Bassindaniel
Top layer: saturation fx set to zero saturation at full opacity.
Secondary layer: any footage you like.
tijnisfijn
I'm not sure I understand what you want. Can you make a movie maybe that shows the problem or some screenshots.
Bassindaniel
I’m talking about using the top layer as FX layer which affects the bottom layers.
I’ll record some video later today. Thanks.
Christoph
Post by Christoph »
If you disable the alpha channel with the RGBA swatches from your effect clip this should work as expected.
Screenshot 2025-05-21 150148.png (10.84 KiB) Viewed 31133 times
Bassindaniel
Christoph wrote: Wed May 21, 2025 14:02 If you disable the alpha channel with the RGBA swatches from your effect clip this should work as expected.
Now. That’s a solution.
Thanks a lot.
