FF missing parameters????
Ozz
Post by Ozz »
Some FF xf seem to have lost some of their fonctionalities... Namely the scanner fx and the SZ-Polaroids fx. I've tried changing every parameters but the effects are either stuck in the upper corner and not scaling (scanner) or not responding to some settings (Polaroids, impossible to get the border... )
I just tested R2.41 today, I am missing something?
Thanks in advance for replying.
OZZ
Try deleting the the fx.xml file in your ~/My Documents/Resolume 2.4/settings folder. Let us know if that helps.
Ozz
Post by Ozz »
Yes that's the solution, thanks.
OZZ
