Hello, all
When using Arena on a Mac, there is a red dot in the upper right corner of the display when I use timecode.
Has anyone encountered and solved this problem?
Both Mac studio with M1 processor and MAC pro with M2 processor have this problem
Thank you
A red dot in the upper right corner of the display
Re: A red dot in the upper right corner of the display
That is a privacy "feature" from MacOS warning you that an app is accessing your microphone.
Check out this article how to get rid of it:
https://support.apple.com/en-us/118449
Thank you very much!Christoph wrote: Fri Jun 27, 2025 15:53 That is a privacy "feature" from MacOS warning you that an app is accessing your microphone.
