is there any way to record my resolume output to my dv cam via firewire?
cheers,
armitage
recording to camcorder
Yeah. Just use your video output on your computer hooked to your cam. Then, use rec control ou something like that to put your camera on standby. Then, start recording and play with resolume.
If you want to do it live, you'll need some splitter to the cable or a mixer. Put the basic concept is the same
armitageshanks
